Activity Forums Adobe After Effects Random line appearing below objects?
  • Random line appearing below objects?
    Posted by Ladydisdain on July 17, 2006 at 3:38 pm
    Just started encountering this on Friday, and it’s continuing today …
    When adding simple elements like a PSD file of a flag, or even a text layer, to a composition, when I do a RAM preview or render it, a 1-pixel thick line randomly appears below my text and/or below the flag I brought in – and the line, from what I can tell, is a line of color from the flag. (Weird, huh)
    Any idea why this might be happening?
    “Scratching could not make it worse, and t’were such a face as yours were.”
    ~ Lady Disdain
    Steve Roberts replied 20 years, 1 month ago 2 Members · 3 Replies
  • Steve Roberts
    July 17, 2006 at 4:01 pm
    1) are there any 3D layers?
    2) What is the minimum amount of stuff you can put into the comp to make this happen? (e.g. one layer, no effects?)
    3) Does it happen all the time (no matter what is in the comp, in any comp, in a new project, after a restart, with any effects) or only under specific circumstances?
  • Ladydisdain
    July 17, 2006 at 4:08 pm
    Yes, as a matter of fact – aside from the flag, I have a beveled-edge square map swiveling in, with another layer of one of the countries cropped out, swiveling in with it, and it breaks off to larger scale after they both enter.
    Well, the flag (which seems to be the originator of the “line”) initially had the wave warp and drop shadow effects on it – however, once I disabled the drop shadow, the line stopped appearing beneath that flag graphic. However, no drop shadow is present on the text layers, and the line is still appearing under both of those (only effects I’m using there are opacity keyframes).
    I ran into it on Friday, the system was shut down over the weekend, and this morning after starting up, it was still doing it. I’ve only seen it in this project/comp – I’m about to start editing another background similar to this one, so I’ll see if it reoccurs.
    ~ Lady Disdain
  • Steve Roberts
    July 17, 2006 at 4:34 pm
    Can you send me a screengrab of the offending flag comp, and the offending text comp?
    (ads at reidroberts daht calm)
