Activity Forums Adobe After Effects Expressions Random Lightining Strikes
  • Random Lightining Strikes
    Posted by Pat Bray on June 18, 2011 at 12:14 pm
    Hi
    I was hoping to create lightning strikes from one element and wondered if there was a way to write an expression so when that element’s opacity = 0% it would reposition randomly , say 20-30 pixels? (the lightning is flickering using a simple wiggle expression at the moment).
    Any suggestions?
    Pat Bray replied 15 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 18, 2011 at 4:48 pm
    This should give you a new random position every time the opacity goes below 1%:
    p = transform.opacity;
    threshold = 1;
    trig = false;
    for (f = timeToFrames(); f >= timeToFrames(inPoint); f--){
    tCur = framesToTime(f);
    v = p.valueAtTime(tCur);
    if (trig && (v > threshold)) break;
    if (v <= threshold) trig = true;
    seedRandom(f,true);
    offset = random([-20,-20],[20,20])
    value + offset
    Dan
  • Pat Bray
    June 21, 2011 at 9:09 am
    Thank you! Wish I knew expression coding more thoroughly, it’s such a time saver and my workflow is so much tidier, unlike my desk… 😛
