Activity Forums Adobe After Effects Expressions random hold periods
  • random hold periods
    Posted by Jason Corder on May 7, 2009 at 4:07 am
    i’m trying to create an expression that periodically turns the opacity of a layer to 100% but then holds that opacity value at 100 for a period of say, 10 frames of time. here’s what i’ve got so far…
    x=random(50);
    if(x>45){
    value=100;
    }else{
    value=0;
    obviously that expression produces some chaotic results as a new random number for ‘x’ is created at every frame. so how can i create the hold? if anybody has an example or link to another post here that would be awesome!
    Darren Hardaway replied 17 years, 2 months ago 2 Members · 3 Replies
  • Darren Hardaway
    May 7, 2009 at 6:50 am
    see if this works
    wiggle(1,100)
    it worked pretty well for me, kinda random and it held the 100% opacity for a good amount of time.
  • Jason Corder
    May 7, 2009 at 4:02 pm
    hey thanks for the feedback! i guess i was looking for more of a square wav with some pulse width modulation to achieve a slow ‘geiger counter’ esque pulse light effect. so the layer triggers ‘on’ only every so often and stays on for a slightly varying period of time(the goal is between 1-2 seconds)…
    maybe an expression slider in null layer with a posterizeTime(3) or something attached to the if/else statement in the opacity of the other layer would do the trick?
  • Darren Hardaway
    May 13, 2009 at 4:32 am
    hehehe, I don’t even know what posterizeTime does, I’m just really starting with expressions. But what I think you are trying to do is force the solid to hold 100 opacity for a random time between 1-2 seconds? You could use an if/else to tell it when to turn “on” but how to use a random number generator to tell how long to stay “on” then turn “off” would be beyond me.
