Activity Forums Adobe After Effects Expressions Random frames without repeat
  • Random frames without repeat
    Posted by Kasper Werther on October 9, 2015 at 12:20 am
    I’ve been searching around for a few hours to get this done.
    I have a 12fps composition containing 132 unique frames. I want the composition to play the frames in random order, without repeating a frame.
    I found multiple scripts, of which the one from this thread came very close: https://forums.adobe.com/message/4577715
    fr = 12; // frame rate;
    numFrames = 132;
    seedRandom(index,true);
    seg = Math.floor(time*fr);
    f = Math.floor(random(numFrames));
    for (i = 0; i < seg; i++)
    f = (f + Math.floor(random(1,numFrames)))%numFrames;
    framesToTime(f);
    Only the thing is, I see frames being repeated a few times. I tried messing around a bit, but I can’t seem to get it right. What do I add to prevent this? (and where in the code)
    Ilya Sire replied 9 years, 10 months ago 3 Members · 5 Replies
  • Dan Ebberts
    October 9, 2015 at 5:14 am
    Do you mean that you want each fame to display once, and only once in the complete sequence of frames, or do you just need the same frame to not show twice in a row?
    Dan
  • Kasper Werther
    October 9, 2015 at 10:02 am
    I only want to display each frames once, and only once in the complete sequence of frames 🙂
  • Dan Ebberts
    October 9, 2015 at 5:29 pm
    I think this is close to what you’re looking for:
    numFrames = 132;
    a = [];
    for (i = 0; i < numFrames; i++)a.push(i);
    for (i = 0; i < numFrames; i++){
    idx = i + Math.floor(random(a.length - i));
    temp = a[i];
    a[i] = a[idx];
    a[idx] = temp;
    idx = timeToFrames(time)%numFrames;
    framesToTime(a[idx])
    Dan
  • Kasper Werther
    October 9, 2015 at 7:43 pm
    It seems to work, I did not notice a repeated frame yet!
    Thank you, much appreciated!
  • Ilya Sire
    November 23, 2016 at 1:29 pm
    Hi Dan Ebberts,
    How to make this code always start with 0 frame and then next random?
    Sire
