Activity Forums Apple Final Cut Pro Legacy Random Frame Rate Question
  • Thomas Lee
    March 6, 2010 at 8:31 pm
    No. You will need to convert one frame rate to another. Compressor is what you use.
  • Matt Campbell
    March 8, 2010 at 7:23 pm
    I wouldn’t recommend it. If you did, FCP will add in the wrong pull-down to the 23.98 footage to make it 30 fps or 29.97. There are better ways to convert the 23.98 clips but Compressor will do a decent job of it. Just make sure you use Compressors frame controls to help with the rate conversion.
    OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
