Activity Forums Adobe After Effects Expressions Random frame on trigger
  • Random frame on trigger
    Posted by Justin Stephenson on June 12, 2014 at 6:39 pm
    Hello,
    I am working on an animation in which I would like to trigger a random frame in a frame sequence based on an audio event (an irregularly timed click). The frame would hold until the next trigger.
    I can very easily create a boolean switch from the audio using soundkeys or an expression. I am having a more difficult time figuring out how I would use this to trigger a random frame which would hold until the next trigger.
    I would appreciate it if someone could point me in the right direction.
    Best,
    – Justin
    Design, Animation, Editing, Color for Cinema, Broadcast, Web and Installation.
    Gear: 2 X Macpro 8 Core Nehalem, ATTO R380, Proavio EB8MS, nVidia GTX-286, Blackmagic Decklink Studio, AJA LHi, FSI LM-2461W, Tangent Wave, Yamaha HS50Ms W HS10w Sub
    Tools: Avid MC 5.5 (formerly FCP), CS 5.5, C4D13, Resolve 8.1, VDMX, Quartz Composer, Processing, Cubase 5.
    Justin Stephenson replied 12 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 12, 2014 at 6:56 pm
    I think you first need to count how many triggers there have been up to the current time. This should help with that:
    https://www.motionscript.com/design-guide/audio-count.html
    Then use the resulting value (n) to seed the random number generator:
    seedRandom(n,true);
    Then select the random frame:
    framesToTime(Math.floor(random(number_of_total_frames)))
    Something like that.
    Dan
  • Justin Stephenson
    June 12, 2014 at 7:48 pm
    Perfect! Thank-you, Dan. I also used the counter to create random seeds for some fractal noise layers that I am using for textures and light.
    The end effect is that each time the bass drum is hit, a new background appears.
    Best,
    – Justin
