Activity Forums Adobe After Effects Expressions random for 10 secs, then loop those numbers
  • random for 10 secs, then loop those numbers
    Posted by Bert Brown on January 4, 2010 at 1:58 am
    I’ve searched for looping random numbers, but nothing seems to be helping in what I’m looking for.
    How can I have a random number generated every second for 10 secs and then repeat the sequence until I change the seed (which would then repeat the new sequence)?
    All I seem to be able to do is have a second layer generating the random sequence and then using the attached expression, which isnt ideal.
    A = thisComp.layer("Cyan Solid 2").effect("Numbers")("Value/Offset/Random Max");
    T = time%10;
    A.valueAtTime(T)
    Dan Ebberts
    replied 16 years, 8 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    January 4, 2010 at 3:56 am
    Something like this will give a different random number (between 0 and 100) every second for ten seconds, then repeat. This will continue until you change the seed:
    seed = 113; // whatever you want here
    t = Math.floor(time%10);
    seedRandom(seed*10+t,true);
    x = random(100);
    Dan
