Activity Forums Adobe After Effects Expressions Random ease between two values with minimum and maximum on-off times
  • Random ease between two values with minimum and maximum on-off times
    Posted by Noel Powell on March 28, 2018 at 2:44 pm
    I’m exploring ways to have a property randomly ease between two values, but with a several controlling factors built in. I’ve used this expression from Dan Ebberts before, which works great for creating random blinking between two values (in this case, 0 and 100), using slider controls to determine the minimum and maximum on times, and minimum and maximum off times. What I can’t figure out is how to modify the expression to make it ease between the two values over a set amount of time.
    For example, if there was a slider control named “easeDuration” that was set to 0.5, then every time the property goes from 0 to 100, I’d like it ease from 0 to 100 over a period of 0.5 seconds, and then when it goes back to 0, it would do so over a period of 0.5 seconds.
    I’ve tried many times to wrap my head around all of Dan’s brilliant articles on expressions, but my brain can only follow up to a certain point. Any help is greatly appreciated!
    minOnTime = effect("Minimum On Time")("Slider");
    maxOnTime = effect("Maximum On Time")("Slider");
    minOffTime = effect("Minimum Off Time")("Slider");
    maxOffTime = effect("Maximum Off Time")("Slider");
    i = 0;
    tEnd = 0;
    seedRandom(index,true);
    preRun = random(maxOnTime);
    while (time + preRun >= tEnd){
    i++;
    if(i%2){
    tEnd += random(minOnTime,maxOnTime);
    result = 100;
    }else{
    tEnd += random(minOffTime,maxOffTime);
    result = 0;
    result
    After Effects Templates – digital glitch effects, 80s VHS effects, old film effects, art effects, and more: https://CreationEffects.com
    Noel Powell replied 8 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 28, 2018 at 7:23 pm
    Something like this maybe:
    easeTime = effect("Ease Time")("Slider");
    i = 0;
    preRun = random(Math.min(maxOffTime,maxOnTime));
    t = time + preRun;
    tEnd = 0;
    while (t >= tEnd){
    i++;
    tPrev = tEnd;
    if(i%2)
    else
    if (i%2)
    ease(t,tPrev,tPrev + easeTime,0,100)
    else
    ease(t,tPrev,tPrev + easeTime,100,0)
    Dan
  • Noel Powell
    March 28, 2018 at 8:17 pm
    Works beautifully, Dan. Thank you so much!
