Activity › Forums › Adobe After Effects Expressions › Random direction change constrained to 90 degrees
  • Random direction change constrained to 90 degrees
    Posted by neil sanderson on May 26, 2021 at 5:48 am
    Hey guys, I’m looking for some expression help. I have a square shape layer setup within a grid system. Every 25 frames I would like that square to slide in to a random adjacent square in the grid, so every 25 frames the layer randomly moves either up, down, left or right in to another square in the grid.
    neil sanderson replied 5 years, 4 months ago 2 Members · 3 Replies
  • Filip Vandueren
    May 26, 2021 at 9:07 am
    This seems to work:
    seedRandom(index,true);
    moveDistance = 100;
    moveEvery = framesToTime(25);
    startPos = [960,540];
    moves=[startPos];
    possibleMoves = [[1,0],[-1,0],[0,1],[0,-1]];
    st = thisLayer.startTime;
    // create all moves up front
    for (i=0; i < (thisComp.duration - st); i+=moveEvery) {
    move = possibleMoves[ Math.floor(random(4)) ];
    lastPos = moves[moves.length-1];
    newPos = lastPos + move*moveDistance;
    moves.push(newPos);
    t=(time-st)%moveEvery;
    step = Math.floor((time-st)/moveEvery);
    easeOut( t, 0, moveEvery, moves[step], moves[step+1]);
  • Filip Vandueren
    May 26, 2021 at 9:39 am
    This version is better if you experience glitches: (sometimes doing % and / operations on time gives glitchy results, it depends on the framerate. using timeToFrames() can fix that)
    moveDistance = 100;
    moveEvery = 25;
    moves=[startPos];
    for (i=0; i<timeToFrames(thisComp.duration - st); i+=moveEvery) {
    moves.push(newPos);
    f=timeToFrames(time-st);
    t=f%moveEvery;
    step = Math.floor(f/moveEvery);
    ease( t, 0, moveEvery, moves[step], moves[step+1]);
  • neil sanderson
    May 27, 2021 at 2:02 am
    This is incredible! Thank you so much Filip, both for the quick reply, and the awesome expression.
