Activity › Forums › Adobe After Effects Expressions › Random delay in time remapped animation
  • Random delay in time remapped animation
    Posted by Michał Orzełek on September 17, 2013 at 12:20 pm
    Hello everyone!
    I am new to expression and have lots of problems with that. I would be really grateful if someone could help me.
    I tried to make randomly delayed animation that is a time remapped composition. As a final result I wanted to have 9 copies of the layer that randomly plays the looped animation. The picture below describes better the situation:
    https://dl.dropboxusercontent.com/u/896453/AE_concept.png
    The composition has 25 frames of looped animation. The problem I have is that I cannot set a random delay of that loop.
    I tried that solution : https://www.motionscript.com/mastering-expressions/random-1.html (Back to the Task at Hand section), but I cannot play whole looped animation. Works fine for position control.
    I think I should create a “while loop” that will last for animation duration, then get a random number which will be an offset for animation. I don’t event know if my thinking is correct.
    Best regards,
    Michal Orzelek
    Michał Orzełek replied 13 years ago 1 Member · 1 Reply
  • Michał Orzełek
    September 20, 2013 at 12:32 am
    I give up ;/
    What I created is only a random offset that changes after each animation time. It doesn’t play the animation from the beginning. I guess there is no way to check what is the current value of time remapping.
    My code was:
    animDur = framesToTime(25)
    numberOfAnims = Math.floor(time/animDur)+1 // plus fist run
    seedRandom(numberOfAnims,true)
    offset = random(0,2) // random duration 0 - 2 seconds
    valueAtTime((time%animDur)-offset) // get the animation
