Activity › Forums › Adobe After Effects › Random colour fill from a range of preselected colours
  • Walter Soyka
    December 7, 2020 at 9:53 pm
    Assuming you have a Fill in each group in the shape layer, I’d add an expression to each Fill so they each display a random brightness value from black [0,0,0] to white [1,1,1]. Then I’d use a Colorama effect on the layer (with Interpolate Palette set to Off!) to force the windows to your specific palette.
    You can use an expression like this:
    // use seedRandom to generate a "timeless" value
    seedRandom(1, true);
    // pick a random number between 0 and 1
    var x = random();
    // put that same random number into the red, blue and green channels
    // to give us a brightness value. Keep alpha full!
    [x,x,x,1]
    I’ve attached a sample project that shows how it all works together. Please ask questions if anything isn’t clear!
