  • Posted by Matt Bacon on June 18, 2018 at 7:32 pm
    Hello,
    I would like a shape layer to randomly alternate between 4 specific colors. My if/else statement appears to be working (when I manually assign a value between 1-3 to the variable c, the color of my shape changes).
    When I use
    “seed = Math.floor(time);
    seedRandom(seed,true);
    c=random(1,3);”
    c appears to take a value beyond 1-3 and hold that value across time.
    I suspect I’m making some simple error, but my syntax looks correct! Any help is greatly appreciated.
    -Matt
    //c=1;
    c=random(1,3);
    if (c==1) {[3,130,171,255]/255;}
    else if (c==2) {[128,207,217,255]/255;}
    else if (c==3) {[2,146,113,255]/255;}
    else {[255,102,0,255]/255;}
    Dan Ebberts replied 8 years, 3 months ago 2 Members · 3 Replies
  • Dan Ebberts
    June 18, 2018 at 8:51 pm
    Try changing this:
    c=random(1,3);
    to this:
    c = Math.floor(random(1,5));
    Dan
  • Matt Bacon
    June 18, 2018 at 9:04 pm
    Thanks Dan!
    That worked immediately. Do you mind explaining that to me? I’m clearly an expressions n00b and I really don’t follow what just happened.
    Is Math.floor ensuring that the random number is a whole number? I presumed “random(1,3)” would give me one of three integers: [1, 2, 3]
    Regards,
    Matt
  • Dan Ebberts
    June 18, 2018 at 9:11 pm
    Yes, it rounds down.
    random(1,3) will give you a non-integer number greater than 1 and less than 3.
    Math.floor(random(1,5)) will give you an integer 1, 2, 3, or 4.
    Dan
