Activity Forums Adobe After Effects Random but predefined increments for counter
  • Random but predefined increments for counter
    Posted by Marko Novkov on January 28, 2021 at 3:53 pm
    Hello,
    I am trying to have my counter grow only by predefined increments (1, 5, 10, 25).
    I have linked it to my control slider and placed keyframes to which values it should go, but it is getting there 1 by 1.
    here is the expression I am currently using and trying to modify further:
    // Pick-whip number from Slider or Point Control and assign to mySlider
    // For example: var mySlider = effect(“Point Control”)(“Point”)[0];
    var mySlider = thisComp.layer(“CONTROL mn”).effect(“COUNTER”)(“Slider”)*10;
    // Use the commas function defined below to format your number.
    // Commas takes three properties – the number input,
    // the size of the groups of numbers and the number of decimal places.
    // You can use this function and only give it the base number.
    var numberstring = commas(mySlider);
    // This is the final output of this expression.
    // Use quotes around other text that you want to join with your numberstring variable.
    // eg. ‘$’ + numberstring + ‘ RAISED’
    ‘ ‘ + numberstring;
    function commas(number, groupSize, decimals){
    // Default settings if only a number is provided.
    groupSize = (groupSize == undefined) ? 3 : groupSize;
    decimals = (decimals == undefined) ? 0 : decimals;
    var theComma = ” “;
    // Round to given decimal places and convert number to string
    var strNumber = Number(number).toFixed(decimals).toString()
    // Store decimal places separately, with a bullet point if they exist or empty string if not.
    var arrNumber = strNumber.split(‘.’)
    var decimalPlaces = (arrNumber.length > 1) ? ‘.’ + arrNumber[1] : ”;
    // Convert to array to split into characters
    var anum = arrNumber[0].split(”);
    // New array to hold formatted number
    var fnum = new Array();
    var count = 0;
    // Process the characters in reverse, inserting a comma after each groupSize.
    for(var i = anum.length-1; i >= 0; i–){
    fnum.push(anum[i]);
    count++;
    // If the count is divisble by the groupSize and this is not the last (ie. first) character, add a comma.
    if(count % groupSize == 0 && i != 0){
    fnum.push(theComma);
    return fnum.reverse().join(”) + decimalPlaces;
    Thank you so much for any help ♥
    Liran Tabib replied 5 years, 7 months ago 3 Members · 5 Replies
  • Kevin Camp
    January 28, 2021 at 4:22 pm
    Are you using hold keyframes on your slider? AE will interpolate between keyframes unless you set the keyframes to hold. To do so, select all the keyframes and then right-click on one fo them and choose ‘Toggle Hold Keyframes’
  • Marko Novkov
    January 28, 2021 at 4:36 pm
    Thank you Kevin,
    I am not using the hold in this case since I need the counter to count many times until reaches the point where it should stop for a bit.
    For example: I need the counter to continue from 1250 until 4500 between the two slider keyframes, but the increments to be random from the predefined 5.
    Thank you so much !
  • Kevin Camp
    January 28, 2021 at 9:41 pm
    That will be a bit more difficult… I’m not sure how to get that to happen. I can make an array of the increment values and randomly grab a value from that array and add that to the counter as it counts, however if the random increment is 25 at one frame, then 1 on the next the frame the counter will actually decrease…
    you might ask on the expressions forum, there are definitely users over there that are better at expressions than I am.
  • Marko Novkov
    January 29, 2021 at 8:37 am
    Ah thank you so much, this already helps because I already thought I am on the expressions forum ?.
    Thank you! Have a good one
  • Liran Tabib
    January 29, 2021 at 9:52 am
    To create increments of a number you can add the expression:
    value-(value%5)// subtracts the remainder of five from the number
    It can be placed on a slider that drives the numbers or on the Number value of Counter Preset
    Cheers
