Activity › Forums › Apple Final Cut Pro Legacy › Random audio cutting out completely in Exported QUICKTIME
Posted by Victor on May 26, 2005 at 5:06 amSometimes it’s all the layers, sometimes it’s several, and only one stays. Only about 3-4 times in a 4:11 sequence. Everything is fine in my timeline. It’s ONLY when I export to quicktime????? Any suggestions?
Thanks in advance!
Pdr replied 21 years, 4 months ago 3 Members · 6 Replies -
Pdr
May 26, 2005 at 5:10 amHey DSCA
Have you tried exporting as follows:
1. Select sequence in the Browser
2. Go to File > Export > Export to AIFFs -
Victor
May 26, 2005 at 5:20 amthank you for trying to help though. But, what can I do now????!?! This sucks.
Stuart Simpson
May 26, 2005 at 6:24 amTry an audio mixdown before you export your audio. It’s under the sequence menu > render > mixdown
-Simmie
1 G5 – Cinewave
5 G4s – Cinewave
1 xbox, 1 PS2 & a Gamecube
https://www.speak.co.uk -
Pdr
May 26, 2005 at 6:35 amHey DSCA
First rule: Don’t panic. Relax. Take a deep breath. 😉
Some further questions:
1. Does the error occur when you playback on the timeline?
2. Is the error predictable or random
Victor
May 26, 2005 at 7:28 amit was the same spots. I fixed it though. I just exported as DV instead. Then used that DV and exported it to Quicktime….. Seemed to work. But I think maybe deleting render files may have too.
thanks for your help guys!
Pdr
May 26, 2005 at 8:39 amYes, definitely sounds like render files to me.
Had the same problem before.Glad to see you back on your wheels!
Regards
Peter—
Peter Dominic Ryan – Freelance Editor
raycity* media – pdr@raycity.comPowerMac G5 Dual 2.0 GHz, 4GB, Mac OS X 10.4
FCP 5, Soundtrack Pro, Motion 2, DVD SP 4
