Activity Forums Maxon Cinema 4D Random appearing of black points on render
  • Random appearing of black points on render
    Posted by Alex Fecit on February 25, 2016 at 7:05 pm
    Hello!
    I have a problem with Cinema 4D physical render! I’m very confusing. Black points is appearing on randomly frames in render sequence (pic). Just rerender these frames fixes it. But I’m get tired to make rerenders bad frames.(usually it is 5-10% frames in sequence)
    And I can’t catch it to know what is the problem because after rerender this points usually disappears.
    Andy Sills replied 10 years, 6 months ago 3 Members · 2 Replies
  • Brian Jones
    February 25, 2016 at 11:07 pm
    haven’t seen that, does it do that if you turn off the Ambient Occlusion or Global Illumination (Either or both at the same time?)
  • Andy Sills
    February 29, 2016 at 8:38 pm
    Another question, are you using team render??
    Ive had team render do some nutty things and one of them is rendering certain frames as black.
