Activity Forums Adobe After Effects RAM/RENDER problem with AE and MacBook Pro
  • RAM/RENDER problem with AE and MacBook Pro
    Posted by David Escurriola on April 2, 2014 at 1:44 pm
    Hi everybody
    My new MacBookPro is not working propertly. The Renderspeed slows down.
    The normal render time used to be 4h, but now after several renders it takes 12h and is not jet finished!
    My old MacPro (Early 2008, 16GB RAM) renders the sequence in 8h: no problems.
    The renderspeed slows actually after 10-15 Minutes down.
    I am producing a Art sequence: 41000 Frames (26 Minutes @ 30fps) with masks,
    mash warps, plugins: revision re:flex warp and re:flex motion morph for morphing in
    between faces.
    My settings before I started to render:
    Purged memory and emptied disk cache, cleaned database & cache,
    (OFF) Multiprocessing
    (ON) Reduce cache size when system is low on memory
    Then I went to the “Secret Settings” and selected “Disable Layer Cache” and
    Purge every 100 frames during make movie.
    Device: MacBook 2.3 GHz Intel Core i7, 16 GB 1600MHz DDR3 RAM, Mac OS 10.9.2
    System preferences: Energy saver:
    (Never) Turn display off after…
    (OFF) Put hard disks to sleep when possible
    (ON) Prevent computer from sleeping when he display is off
    What else can I check? I’ve been reading older posts about the same issue,
    but I’m still struggling with it!
    Thanks for your support
    David
    Brian Charles replied 12 years, 5 months ago 3 Members · 5 Replies
  • David Escurriola
    April 2, 2014 at 4:14 pm
    Hi Dave
    Thanks for your support. Yes, I’m running AFX 12.2 and OS X 10.9.2. Both are the newest one.
    Multiprocessing is turned off.
  • Walter Soyka
    April 2, 2014 at 4:15 pm
    [David Escurriola] “The renderspeed slows actually after 10-15 Minutes down.”
    Does it always slow down around the same frame in the render? Is there some effect coming in around that point in your timeline?
    [David Escurriola] “My settings before I started to render:
    Purged memory and emptied disk cache, cleaned database & cache,”
    Don’t do this. You should only empty the disk cache if you are seeing corrupt frames in your render. Otherwise, you are disabling a feature that can save you a lot of render time by reusing previously-rendered frames.
    [David Escurriola] “(OFF) Multiprocessing”
    With 16 GB of RAM in your system, I think you can turn multiprocessing ON — just make sure you’re leaving ample RAM for other apps (I’d start with 6 GB) and make sure that each instance of Ae has enough minimum RAM (I’d start with 3 GB per process). This will limit you to 3 CPUs max, but 3 is better than 1.
    [David Escurriola] “Then I went to the “Secret Settings” and selected “Disable Layer Cache” and
    Purge every 100 frames during make movie.”
    This was good advice pre-CS5 when Ae was 32-bit and was always running out of RAM. By disabling the layer cache and purging memory every 100 frames, you are preventing Ae from saving things in RAM, forcing it to recalculate more while rendering, and slowing yourself down.
    [David Escurriola] “What else can I check?”
    I’m not running Mavericks myself yet, but maybe you should turn off App Nap?
    https://helpx.adobe.com/creative-cloud/kb/app-nap-reduces-application-performance.html
    Walter Soyka
  • David Escurriola
    April 2, 2014 at 5:03 pm
    Hi Walter
    Thanks for your support!
    To your questions:
    01. Is there some effect coming in around that point in your timeline?
    No, the pre rendered Sequence ist ProRes422HQ and it is all the same. The content has no influence on the problem.
    02. I agree, but for this long sequence of 26minutes, it doesn’t seem to make a difference.
    03. Multiprocessing: Either way with or without Multiprocessing, this problems appears. But I usually render without Multiprocessing. It doesn’t seem to be trustworthy, in my opinion.
    04. Secret Settings: The settings used to be by “1000” Frames at the beginning, but I reduce it yesterday to try something else. I will put it back to 1000 Frames.
    05. Prevent “AppNap” is not turned on.
    My question is still the same: Why is the render speed so slow newly?
    One month ago, when I bought the MacBook it started to render the sequence within 4 hours. Later on the render speed started to decrease. I thought it was the external 2TB thunderbolt LaCie HD. But then I realised, that the problem persists even working with all the files on the local SSD HD.
    Thanks for your help! 😉
    Cheers
    David
  • Walter Soyka
    April 2, 2014 at 5:29 pm
    What format are you rendering to? Is it a QuickTime format? Does it make a difference if you render to a different format? For a project of your length, I’d suggest rendering to an image sequence.
    RAM usage seems low. Your screenshot shows Ae only taking 1 GB out of 16. All the stuff you are doing in the Secret menu are techniques that sacrifice speed in order to conserve RAM and should be quite unnecessary here.
    [David Escurriola] “03. Multiprocessing: Either way with or without Multiprocessing, this problems appears. But I usually render without Multiprocessing. It doesn’t seem to be trustworthy, in my opinion.”
    Multiprocessing, more than anything else, is the thing that can improve your Ae render times. I don’t always use MP for RAM previews, but I do all my final renders with MP.
    [David Escurriola]
    05. Prevent “AppNap” is not turned on.”
    Try checking the box to prevent App Nap.
    Walter Soyka
  • Brian Charles
    April 2, 2014 at 6:34 pm
    I note from the screen captures that the QT32 Server isn’t responding, there’s a long thread on this in the Adobe forum:
    https://forums.adobe.com/thread/1360633
