Activity › Forums › Apple Final Cut Pro Legacy › ramping and slow motion
  • ramping and slow motion
    Posted by Paolo Mugnaini on January 8, 2007 at 9:38 pm
    I’ve tried to apply slow motion effect and i get a freeze frame, i looked for a frame rate but no luck, I was used to avid where you select the in and outon your viewer and then apply the speed choosing the %age rate. it’s similar on FCP but when I tried, it froze my clip. ??? shall i use the ramping feature for it? i ended up matching a frame and cutting the clip.
    I still haven’t grasped the ramping thing, I should be able to slow mo’ too right? is there an easy way to explain it?
    thanx!Paolo
    Paolo Mugnaini replied 19 years, 8 months ago 2 Members · 2 Replies
  • David Battistella
    January 8, 2007 at 10:26 pm
    park on the frame you want to freeze.
    in the modufy menu selct make freeze frame.
    the freeze appears in the viewer. its better to cut it up than to use time remapping for this.
    David
    Peace and Love 🙂
  • Paolo Mugnaini
    January 9, 2007 at 2:36 am
    David Thanks!
    I know How to freeze a frame, it’s when I am trying to slow mo’ a clip through ramping that i get a freeze frame.
    thanks
    Paolo
