Activity Forums VEGAS Pro Rampant Chamber Effects – Anyone use with luck?
  • Rampant Chamber Effects – Anyone use with luck?
    Posted by Scott Francis on October 5, 2016 at 6:48 pm
    Hey All,
    Purchased the Rampant Design Chamber FX (and numerous others as well0, MVP 14 will not allow me to drop them into my timeline. I had issue with them in SVP13 and just remuxed them in Avidemux to use them. I tried that this time and it throws me errors. Anyone had any luck with these and if so how?
    Thanks for your help!
    Xavier (Scott) Francis
    Mind\’s Eye Audio/Video Productions
    Scott Francis replied 9 years, 11 months ago 2 Members · 3 Replies
  • Scott Francis
    October 5, 2016 at 6:52 pm
    Here is what mediainfo gives me as far as data:
    General
    Complete name : I:\Rampant Mattes\New Purchase\Ink\Rampant_Mograph_Essentials_Ink_001.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2005.03 (qt )
    File size : 201 MiB
    Duration : 33 s 867 ms
    Overall bit rate mode : Variable
    Overall bit rate : 49.7 Mb/s
    Encoded date : UTC 2014-11-04 22:10:11
    Tagged date : UTC 2014-11-04 22:14:32
    Writing library : Apple QuickTime
    ©TIM : 10:35:19:20
    ©TSC : 2997
    ©TSZ : 125
    Video
    Format : ProRes
    Format version : Version 1
    Format profile : 4444
    Codec ID : ap4h
    Bit rate mode : Variable
    Bit rate : 49.4 Mb/s
    Width : 4 096 pixels
    Height : 1 728 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Chroma subsampling : 4:4:4
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.291
    Stream size : 200 MiB (100%)
    Language : English
    Tagged date : UTC 2014-11-04 22:10:11
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 10:35:19:20
    Time code, striped : Yes
    Language : English
  • Steve Rhoden
    October 6, 2016 at 12:06 pm
    I have heard complaints over time about users of Vegas with the same issue you are having with Rampant,
    but im not quite sure why this is so. I use many of Rampant’s files without an issue, but i’m summarizing
    that maybe due to the fact i have many a varied codecs installed on my work system.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Scott Francis
    October 6, 2016 at 2:00 pm
    I have tried to save with Quicktime pro, avidemux and looks likeI MAY have found one of the “converter” in EZ Encode to work. It is REALLY frustrating to me as there are like hundreds of files and I have spent nearly 8 hours trying to convert them or get them to the correct format.
    They are just so cool and I really need them for some of my projects, but this is really a pain.
    Thanks for your input!
