Activity Forums Adobe After Effects Ramp up effect working oddly.
  • Ramp up effect working oddly.
    Posted by Ren Junz on May 15, 2014 at 3:44 am
    I’ve tried this multiple times, using multiple files and looking at numerous threads to no avail.
    I only get half the animation, I want each letter to come in individually at different times so I used the “Ramp Up” feature of a Range Selector.
    Please help me ASAP because this has been bothering me for a long time.
    Ren Junz replied 12 years, 3 months ago 2 Members · 2 Replies
  • Darby Edelen
    May 15, 2014 at 5:08 am
    When using a Ramp Up or Ramp Down selector shape you’ll generally want to animate the Offset instead of the Start and End values.
    For example, if your start and end values are 0% and 100% respectively then you’d animate your Offset from -100% to 100%. If your start and end are 0% and 50% then you’d animate your Offset from -50% to 100%.
    The Offset is what actually slides the ramp through the characters. The Start and End values only define the width of the ramp.
    Darby Edelen
  • Ren Junz
    May 16, 2014 at 1:43 am
    Thanks but when using this feature it doesn’t look very smooth.
    If anyone can help me further.
    The whole animation does not go through the “t” but I would like it to.
    I have no idea what to do.
