Activity Forums Adobe After Effects ramp on text layer
  • ramp on text layer
    Posted by Don Logan on February 19, 2008 at 2:32 am
    trying to apply a ramp effect to a text layer. Yeah it’s easy I know. Problem is the ramp is not showing up. Had a look at different drop downs, tried adjusting the ramp etc. Looked at the manual…. Nada.
    Anyone have any suggestions,
    Simon Bonner replied 18 years, 7 months ago 3 Members · 2 Replies
  • Filip Vandueren
    February 19, 2008 at 4:52 am
    Hmm,
    in CS3 it works, though a better way would be to use the “Gradient Overlay” Layer Style, as it is pinned to the text and moves/scales with the text. It does however not rotate.
    Pre-CS3 the best way is perhaps to add the ramp to a Solid, and apply the text as a Alpha Trackmatte.
    You can then Parent the solid to the text, and you will be able to rotate/scale/move the ‘ramped text’
  • Simon Bonner
    February 19, 2008 at 1:17 pm
    I have discovered that you can make the gradient overlay layer style rotate along with your text by adding the following expression to the Angle property of the style:
    value+(transform.rotation*-1)
    Now when you rotate the text layer, the gradient should rotate along with it.
    Simon Bonner
    youtube.com/simonsaysFX
