Activity Forums Apple OS X RAM upgration
  • RAM upgration
    Posted by Niti Shah on January 11, 2008 at 11:32 am
    hello
    I am trying to upgrade Macpro RAM from 2 GB to 4 Gb. Originally I had 1GB two modules (Kingston). When I added two more 1 GB modules with same make same specifications on the same raiser, system started freezing. Later on I changed all the modules but still problem is same. also tried two modules on each raiser. The conclusion is it
    Zane Barker replied 18 years, 8 months ago 2 Members · 1 Reply
  • Zane Barker
    January 11, 2008 at 1:42 pm
    Make sure the ram is paired properly in the computer.
    https://manuals.info.apple.com/en/MacPro_MemoryDIMM_DIY.pdf
    If after paring properly you still have problems, try removing a set of ram and seeing if the issue continues, it is possible you have some bad ram.
    Don’t let technology get in the way of your creativity!
