Activity › Forums › Adobe After Effects › RAM Settings?
RAM Settings?
Posted by Martin Reuben on March 22, 2008 at 9:54 pmNew Mac Pro – 8 core – with 10 gig of RAM installed.
Could someone give me a recommendation for the correct RAM settings in preferences? Typically I would run AE by itself, or with PS at the same time.
Occasionally FCP as well.Thanks!
Martin Reuben
Andrew Sobey replied 18 years, 5 months ago 4 Members · 8 Replies -
Darby Edelen
March 23, 2008 at 5:05 amThe defaults should work well for you.
Max Mem Usage: 120%
RAM Cache: 60%With 10GB of RAM you’ll probably want to enable multiprocessing to make the most of your RAM. At the default Memory & Cache settings this should allow you to render using 5 processors (5 frames at once!)
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Itamar Kool
March 24, 2008 at 10:48 amIn the latest update of After Effects CS3 I saw a recommendation to only enable 4 processors of the 8 when you have about 8 gigs of RAM
Kool En De Anderen
MAC Pro 8 core/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
http://www.koolendeanderen.nl -
Andrew Sobey
March 25, 2008 at 8:39 pmAny idea why you’d want to limit yourself to half the processors? Doesn’t that keep you from using all of your RAM?
Itamar Kool
March 25, 2008 at 9:29 pmAs far as I understand it’s better to have 4 processors using 2 gigs of RAM then 8 using 1 gig.
Kool En De Anderen
Andrew Sobey
March 25, 2008 at 10:19 pmOk, I’m about to reveal my ignorance here, but aren’t you limited to 3GB if you have multiprocessing off?
I’ve seen that this has been written about quite a bit already on the forums, but I haven’t managed to wrap my brain around it quite yet…
Any good links that could explain this for me?
Martin Reuben
March 25, 2008 at 11:21 pmWow – now I’m really confused!
Since I have 10 gig and 8 processors, why can’t I have it all (he asked in a greedy fashion)?
Martin Reuben
Itamar Kool
March 26, 2008 at 9:26 amThis was in the ‘read-me’ files for the 8.0.2 upodate
# Multiprocessing performance issues with multi-core machines, especially high-end 8-core hardware. When all 8 cores try to render a complex or memory intensive composition with Render Mutliple Frames Simultaneously, the application can become memory starved if each process has insufficient memory. To remedy this, there is a text preference to control the maximum number of cores that Render Multiple Frames Simultaneously will use. Open the text preference file and look in the [“MP”] section for: “MaxNumberOfProcesses” = “0”. “0” is the default setting, which disables this preference setting. For better performance on an 8-core machine with 8GB RAM, for example, change the “0” setting to “4” and save the preference file and restart After Effects. This restricts multiprocessing with RenderMultiple Frames Simultaneously to 4 cores, each getting approximately 2GB of RAM.
# For other performance tips using large dimension or complex compositions, see the “Improve performance” section of After Effects CS3 Help on the Web.Kool En De Anderen
Andrew Sobey
March 27, 2008 at 4:54 amThere it is. I finally get it. It was the damn readme file, I should have known. Thanks, now I’m going to go impress some friends and co-workers…
