Activity › Forums › Adobe After Effects › Ram settings – I just need a straight answer
Posted by Stephen Cordes on January 31, 2010 at 7:45 pmI’m really sorry to post this as I’m sure I could find the answer if I looked hard but I just need someone to give me a difinitive answer.
My current setup is a 2.2gz dual core with 4gigs of ram and a decent graphics card. I’m going to be upgrading to 8gigs of ram when I have the budget. Oh and I’m running 64bit windows 7.
Can someone please tell me how much ram per core I should be using in the preferences tab? And whether I should enable multipe core processing? And can someone answer the same question for the 8gig of ram set-up.
Thanks in aniticipation.
Steve
Todd Kopriva replied 15 years, 10 months ago 3 Members · 13 Replies -
Stephen Cordes
January 31, 2010 at 10:36 pmThanks – should I enable multi core processing, and if so, where should the slider be?
thanks.
Todd Kopriva
February 1, 2010 at 12:52 amThis post is meant to answer exactly that question:
https://blogs.adobe.com/toddkopriva/2009/12/performance-tip-dont-starve-yo.html———————————————————————————————————
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Stephen Cordes
February 1, 2010 at 10:10 amThanks very much – you have answered my question. I neither have enough memory or ram to enable multi-core processing. Even when I buy 8gb of ram.
Todd Kopriva
February 1, 2010 at 3:12 pm> Thanks very much – you have answered my question. I neither have enough memory or ram to enable multi-core processing. Even when I buy 8gb of ram.
I don’t know how you came to that conclusion from what I pointed you to.
Yes, 8GB of RAM is enough to use Render Multiple Frames Simultaneously. It’s enough to feed three processor cores (leaving 2GB for other software) for a typical HD-sized composition.
Stephen Cordes
February 1, 2010 at 8:21 pmSorry that should have been I don’t have four cores. Only two
Stephen Cordes
February 1, 2010 at 8:36 pmThanks fir your answers and sorry to keep posting. But the guide you showed me said I should leave a core for the operating system and not set that value to 0 (ie never fire up all your cores). . Could I use one core with 7 gb of ram?
Todd Kopriva
February 1, 2010 at 9:00 pm> But the guide you showed me said I should leave a core for the operating system and not set that value to 0 (ie never fire up all your cores). .
No, it doesn’t say that. It says to never reduce the amount of memory for other application down to zero.
No. The limit per process is 4GB. That is because After Effects CS4 is a 32-bit application.
Stephen Cordes
February 1, 2010 at 9:31 pmI quote from the subpage of the link above. The offici adobe help Manual
“CPUs To Leave For Other Applications Set this value to a number other than 0 to prevent After Effects from using all of the CPUs (processor cores) in your computer system. For example, if you have a computer with 8 CPUs, setting this value to 2 leaves 6 CPUs for After Effects.”
so for me only having two cores I couldn’t set 3gb per core as it would fire up both cores?
Walter Soyka
February 1, 2010 at 9:39 pm[Stephen Cordes] “I quote from the subpage of the link above. The offici adobe help Manual
I read that as more of an explanation than a command. If you had eight cores, you could leave a couple idle during render so you could work on something else and your computer would still have enough horsepower to be responsive. With two cores, if you want to increase your render speed, you can leave it set to 0, but you shouldn’t expect your computer to be very responsive to you while it’s maxed out rendering.
Walter Soyka
