Activity › Forums › Adobe After Effects › RAM previews won’t show full quality.
  • RAM previews won’t show full quality.
    Posted by Jp Pelc on January 2, 2014 at 4:29 pm
    Recently when I try to do a RAM preview AE will only play it back at about 1/4 quality. I have the resolution selected to full in the Comp window and it shows the comp full quality when still, but RAM preview is still low quality. Interestingly enough if I hit spacebar, it will playback at full quality, just not in RAM preview. I’m sure it’s just a setting I need to change but I have played around with settings for adaptive resolution limit, viewer quality, disk cache, video preview, and multiprocessing, all to no avail. Any ideas?
    After Effects CC 12.1.0.168
    OS X 10.8.4
    3.4 GHz Intel Core i7
    8 GB 1600 MHz DDR3
    NVIDIA GeForce GTX 680MX 2048 MB
    Jp Pelc replied 12 years, 8 months ago 3 Members · 3 Replies
  • Walter Soyka
    January 2, 2014 at 5:14 pm
    Look in the Preview panel. You have the option to set custom resolutions (separate from the viewer’s settings) for RAM preview and for Shift-RAM preview.
    Walter Soyka
  • Sam Lanes
    January 2, 2014 at 6:03 pm
    Funnily enough, I recently wrote a blog post which goes through the settings for the RAM Preview function which may help:
    https://www.aefromscratch.com/2013/12/30/working-with-audio-in-after-effects/
  • Jp Pelc
    January 3, 2014 at 3:16 pm
    Thank you Walter!! I knew it had to be a simple solution and I felt like a n00b not being able to figure it out. Much appreciated!
    OS X 10.8.4
    8 GB 1600 MHz DDR3
