Activity Forums Adobe After Effects Ram Previews not long enough
  • Ram Previews not long enough
    Posted by Jody Linton on November 4, 2010 at 2:28 am
    Newbie here at CC! I was wondering if anyone knew how to increase the length that a “Ram Preview” gives, some of the projects I’m working on are over a minute long I find it only previews about 30secs through and I seem to be running into this problem quite a bit now even at “quarter resolution & at 25%” . Are there any settings in preferences that I can adjust that lets me see a longer Ram Preview? (I havent touched them too much really)
    Cheers
    Lauro Garcia replied 15 years, 10 months ago 5 Members · 6 Replies
  • Todd Kopriva
    November 4, 2010 at 4:33 am
    What version of After Effects?
    See “FAQ: Why does RAM preview only play part of my composition?”
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Richard Harrington
    November 4, 2010 at 1:33 pm
    If you run out of RAM… explore Disk Cache options
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Kevin Camp
    November 4, 2010 at 3:36 pm
    in addition to the down sampling that you are currently doing, you can set ram preview (or shift-ram preview) to skip frames. skipping 1 frame will double the duration that you can preview. the setting is in the preview controls (window>preview).
    you can also use the region of interest feature that allows you to preview just a portion of the comp. it’s the button next to the down sample dropdown. click it and draw a rectangle around just a portion of the comp viewer.
    of course the other option is to get more ram, a 64-bit os, and cs5 which will be able to address a lot more ram for ram previews.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jody Linton
    November 4, 2010 at 7:15 pm
    Thanks, I’m using CS4 on a Mac Pro with 2x 3GHZ Quad Core and 10GB of Ram and usually working in 1920×1080, I havent really touched my preferences in AE except I turned “Render multiple frames simultaneously” on only affects final output. Depending on how graphics heavy the project is I usually get about 20seconds of preview using Ram and I usually have Photoshop running at the same time too. Ah, I hadn’t even noticed the region of interest icon next to down sampling and will check the “drop frame” out too.
    Cheers
  • Jody Linton
    November 4, 2010 at 7:34 pm
    Cool, thanks for the link Dave, very helpful.
    Cheers
  • Lauro Garcia
    November 4, 2010 at 7:58 pm
    Hi Jody,
    This might help you. It certainly did me. https://blogs.adobe.com/toddkopriva/2009/12/performance-tip-dont-starve-yo.html
    Goodluck!
