Activity › Forums › Adobe After Effects › RAM Preview Works. Rendering Doesn’t.
  • RAM Preview Works. Rendering Doesn’t.
    Posted by Brent Taylor on June 2, 2015 at 2:12 am
    So I’ve been working on some pretty intense animation projects. A little system-intensive for my modest computer, but the work is getting done. I usually watch my previews at Quarter-quality. But at Full, the system is still capable of rendering things, albeit slowly.
    However, when I try to export, either through the After Effects renderer or the Media Encoder, it freezes off the bat.
    Smaller compositions do ok, so it’s pretty clear that this is just too much for my system. That said, if my computer can do a RAM preview just fine, why can’t it do an actual render?
    This question led me to you guys as I wonder if there are some settings I can tweak to make this work. The fact that it can do a RAM preview on Full without hanging leads me to believe the computer can in fact do it if I find the way to ask nicely.
    I’m also aware of the option to save the RAM preview. Might just have to do that. But I’d prefer to use one of the normal renderers if possible.
    Any ideas?
    Brent Taylor replied 11 years, 4 months ago 3 Members · 5 Replies
  • Tero Ahlfors
    June 2, 2015 at 3:35 am
    [Brent Taylor] “A little system-intensive for my modest computer”
    Well, what are you doing and what are your specs?
  • Brent Taylor
    June 2, 2015 at 3:47 am
    It’s a lot of character animation using .AI layers. A lot of it is in 3D space with Continuous Rasterization on. Some cameras and a little lighting, too. So it can get fairly involved. My specs are like this:
    i7 Quad-core 2.4 ghz
    12 GB RAM
    NVIDIA GeForce FT 640M
    Obviously that’s not amazing. It’s all I can afford at the moment, however.
    If I tell it to render smaller compositions it does fine, but not entire scenes I’ve set up with multiple character/comps, backgrounds, etc. It just freezes.
    I get that the obvious answer is “get a better computer or do simpler stuff.” But I’m hoping that since the RAM preview works just fine, maybe I can get the renderer to do likewise.
  • Tero Ahlfors
    June 2, 2015 at 6:51 am
    How big are the AI files and how big is your render resolution? Have you used any effects? What are your AE memory and multiprocessing settings?
  • Cassius Marques
    June 2, 2015 at 12:24 pm
    Render to a lossless image sequence then import that to a clean project and add your audio again. Send THAT to AME for rendering final delivery.
  • Brent Taylor
    June 2, 2015 at 4:25 pm
    Thanks guys. I’ll look into some of the things you mentioned and get back to you.
    I tried the Media Encoder again last night. I realized that while it LOOKS like it hangs when I send the composition for rendering (Windows even tags it as unresponsive), if I’m very patient and wait a few minutes, it does finally go. It does the same thing when I push the render button.
    Ended up taking 2 or 3 hours to render about a minute and a half of footage.
    Unfortunately the Render has some kind of glitch. There’s a few frames that, for some reason, always render in lower resolution than everything else… odd. This also happened when I saved the RAM preview… can’t figure out what the deal is. Was using the H.264 codec.
    Haven’t tried the image sequence. Will have to get back to you on some of the other settings.
