Activity › Forums › Adobe After Effects › Ram preview with guides?
Posted by Malcolm Desoto on September 16, 2007 at 8:18 pmIs it possible to do a RAM preview with safe title/action guides still on screen?
Thanks.
Malcolm Desoto replied 19 years ago 3 Members · 4 Replies -
Steve Roberts
September 16, 2007 at 8:52 pmSafe areas? No. Just mask a solid with a rectangle to match safe and invert the mask. Or draw masks on a solid and use the stroke effect to make the lines show up. If you don’t want this to render at the end, make it a guide layer.
Guide lines? No. But you can do the mask/stroke thing mentioned above.
Aharon Rabinowitz
September 16, 2007 at 10:34 pmRight – the whole point of a Ram Preview is to show you what the final render will look like. All doodads like guides and safe areas are disabled, so you must create actual layers in your comp to show this.
You can always set up a solid with masks and the stroke effect to create thin lines of a safe area.
Aharon Rabinowitz
arabinowitz(AT)yahoo(DOT)com
http://www.allbetsareoff.com—————————————-
Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
Steve Roberts
September 16, 2007 at 10:45 pm[Aharon Rabinowitz] “You can always set up a solid with masks and the stroke effect to create thin lines of a safe area.”
… and save the thing as a still for future use! 🙂
Malcolm Desoto
September 17, 2007 at 6:37 pmCool. That’s what I thought. Just was wondering if there was an alternate way of doing it.
Thanks for the replies.
