Activity Forums Adobe After Effects RAM Preview – weird issue
  • RAM Preview – weird issue
    Posted by Rob Mason on September 11, 2020 at 7:06 pm
    So I am RAM previewing in AE and I am getting the slow playback and “low-pitched demon voice” for my audio no matter how low I put my settings.
    I’ve tried:
    -Quarter resolution and even 1/16 resolution
    -Making sure my color depth is at 8bpc
    -Turning off all layers that could be slowing things down
    -Playing back with “Skip” set to 1, 2, or even 5.
    I am at a total loss and it is completely ruining my ability to work effectively since I can’t even get a good idea of how my animation is playing out.
    Any ideas?
    Michael Szalapski replied 5 years, 11 months ago 4 Members · 6 Replies
  • Brendon Murphy
    September 11, 2020 at 8:06 pm
    Did your comp frame rate get accidentally changed to something really low?
  • Rob Mason
    September 11, 2020 at 8:15 pm
    Nope.
  • Nick Vaka
    September 11, 2020 at 8:25 pm
    Hey Rob!
    This happened to me too. Somewhere along the line an update disabled “cache before playback” in the preview window. Re-enable that and it should start previewing in realtime again.
  • Brendon Murphy
    September 11, 2020 at 8:28 pm
    A few more things to check:
    Do you have “Enable Disk Cache” checked in preferences? Are you using a folder with sufficient space? Have you emptied the disk cache and cleaned your database and cache recently? Have you tweaked your “fast previews” settings under the viewer window (see image).
  • Rob Mason
    September 11, 2020 at 8:36 pm
    to both of your suggestions, yes I have done these things and I am still getting the same issue. I also constantly Purge All Memory and Disk Cache as well.
    Not sure what else I can do…
  • Michael Szalapski
    September 17, 2020 at 3:27 pm
    What is the exact version number of AE you’re using?
    The whole timeline has the green line, yes?
    Do you have any third-party panels docked? Try changing to one of the default workspaces.
