Activity Forums Adobe After Effects RAM Preview vs. Final Render?
  • RAM Preview vs. Final Render?
    Posted by Jim Dodson on November 27, 2014 at 2:58 am
    I have a comp with several layers of “Add grain” so you can imagine the render time for a RAM preview is excruciatingly slow. I just RAM previewed (took 10 minutes) loved the results and immediately hit “Render” and when I hit the key to start rendering AE had to re-render all those grain layers!! (CS6 / Mac OS X)
    Aren’t those RAM previews saved at fully uncompressed? Why can’t AE use the RAM preview as my final render? I know I can “Save RAM Preview”… But that’s not the question I’m asking.
    Jim Dodson
    8 Core Intel — Mac – OSX
    Graham Macfarlane replied 11 years, 10 months ago 2 Members · 6 Replies
  • Jim Dodson
    November 27, 2014 at 3:09 am
    PS – I have the entire comp Cached to the hard disk – so I can’t understand why those cached RAM preview frames can’t be used for the final render…
    Jim Dodson
  • Graham Macfarlane
    November 27, 2014 at 1:26 pm
    Hi Jim,
    When you initially did your RAM cache, did you have AE set to show full resolution?
    Graham Macfarlane – 3D visualisation and VFX
    3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
    http://www.elyarch.com – London UK
  • Jim Dodson
    November 27, 2014 at 4:52 pm
    Hi Graham-
    Great question – I thought we had cracked it, because I did not have it set to full resolution. But I just ran a test; RAM previewing at full resolution – cache’ing those frames then doing a final render and it does indeed still need to re-render those frames again.
    Jim Dodson
  • Graham Macfarlane
    November 27, 2014 at 6:37 pm
    In the render settings you can set a final render to full, half, third, quarter or custom, just like the setting at the bottom of the main comp window for the RAM/disk caching. I take it they both match?
    Don’t forget that even if AE is rendering from RAM/disk cache, it won’t render at real-time playback speed. This is because it has to compress the data into a video stream or compress the image files and store them too. Depending on the destination location, drive speed and compression choice, you could experience slowdowns of perhaps the order of a second or two per frame for HD.
  • Jim Dodson
    November 27, 2014 at 7:38 pm
    Thanks Graham — thanks to you — I have a solution of sorts… Although, considering my settings and the fact that I am not using motion blur on any layer and the master Motion Blur button remains off, it feels like an AE bug or at least a strange hiccup. Here’s what I discovered:
    My render queue settings automatically sets Motion Blur to “On for Checked Layers”.
    Even though I have no layers with checked motion blur (I’m not using motion blur at all), when I manually change Motion Blur to “off” in the Render Settings, AE successfully uses the Cached frames in the final render and it goes REALLY fast.
    THEN I realized if I change Motion Blur Render Settings to “Current Settings” it also uses the CACHED frames – this is probably the best choice for that setting…
    Thanks again Graham!! Really appreciate it!!!
    Jim Dodson
  • Graham Macfarlane
    November 27, 2014 at 8:08 pm
    Glad you got to the solution!
