Activity › Forums › Adobe After Effects › RAM Preview suddenly very short
  • RAM Preview suddenly very short
    Posted by Marius Shekow on January 6, 2009 at 7:10 pm
    Hello,
    I haven’t worked with after effects for a while, and now I am having two issues:
    1) After Effects RAM preview only can last a few seconds, lets say 3 or so (then it stops automatically, which usually is the behaviour when the RAM is used up). This is the same when using Nucleo Pro or when not using it.
    I have Windows XP x64, 8 GB RAM. As you can imagine, the RAM is NEVER EVER(!!) used up after after effects (CS3) stops rendering the RAM preview. The AE settings (Edit > Preferences > memory&Cache) are at “100% (4,0 GB)”. It used to work before, now it doesn’t. I must have changed something in the months I didn’t work with AE, but I can’t think of anything. Your help would really be appreciated.
    2) After fiddling with installing and uninstalling Graphic drivers (I have a NVIDIA Geforce 8800 GTS) AE now refuses to identify my Card as a OpenGL-compatible one. In the settings dialog the “Enable OpenGL” checkbox is grayed out, and when I click on the info button it says that no compatible OpenGL card could be found, which is incorrect, of course.
    I’m looking forward to any helpful answers 😉
    Kind regards,
    Marius Shekow
    Andrew Francis replied 13 years, 7 months ago 4 Members · 4 Replies
  • Jan Sherlink
    January 6, 2009 at 7:50 pm
    Open-GL
    If you recently updated your Nvidia drivers try to roll them back to the version that worked.
    If not, uninstall Nvidia’s drivers and install new ones.
    Is your Open-GL plug-in installed in the right folder (sometimes people move it for troubleshooting)
    Cache:
    you can try to reset AE’s preferences;
    Hold CTRL+SHIFT+ALT while booting AE
    Seems to fix a lot of errors
    Some thing to try: (bizarre but it fixes quite a lot)
    Create a new user in Windows and work in that user.
    maybe, just maybe …..
    cya,
    Jan
  • Marius Shekow
    January 6, 2009 at 10:10 pm
    THANK YOU 🙂 !!!!
    First of all, I did actually rename the OpenGL.AEX File, I dunno when and why, but it seemed to be a few months ago, shortly after I installed the CS3 suite.
    Apart from that I must have been blind about the settings. I only looked at the first percentage value (“Maximum memory usage”) and forgot and somehow overlooked (O_o) the maximum RAM cache size which was set to 18,9 % (why did I enter that value back then? I dunno!) Now I’ve set it to 90% and I have not yet found a composition that is long enough for my system. Nucleo Pro rendered 30 secs of HD footage without problems.
    Thank you all for your hints ! 😉
  • Adam Bowman
    October 27, 2011 at 10:53 pm
    SOLVED! I had this exact same issue today. AE CS5, Win 7 Home Premium 64 bit, Alienware M17x / 2.5 Core2 / 8GB / 1GB Nvidia card.
    My RAM and audio previews were suddenly limited to 1 frame. I tried rebooting, clearing my preferences, and nothing worked until this article saved my neck…
    All I had to do was boot into safe mode (hold F8 while booting), open and close After Effects, then boot normally. Problem solved, and I can do a RAM preview longer than 1 frame.
    https://forums.adobe.com/message/2859431
    https://acbstudios.com
    Web • 3D • Motion
    Alienware M17x R1
  • Andrew Francis
    February 14, 2013 at 4:19 am
    hey mate i am having that problem but i tried booting up in safe mode and after effects would not open up, so i re-installed it and i worked fine for about an hour and i have the same problem again, the ram render just render out 2 frames and stops dead just wont do it for me if there is any advice please help me out 🙂 thanks
    andy
