Activity › Forums › Adobe After Effects › RAM preview stalls out
  • RAM preview stalls out
    Posted by Bruce Gaber on February 19, 2013 at 11:23 pm
    My RAM preview of a simple 60 sec scan across a 30 Mb PSD file stalls out after about 40 sec. Also when I attempt to run the already rendered preview, AE tries to re-render frames already processed. There appears to be constant updating and swapping of RAM and disk cached data as indicated by changes from green to blue as well as gaps in the render indicator. I’ve tried with MP on/off. Doesn’t help. Rebooted–same problem. Work area is properly set.
    iMac i7, 16Gb
    Disk cache 200 Gb
    RAM allocated 13
    AE CS6
    Thanks to all for you advice
    Bruce
    Vishesh Arora replied 13 years, 7 months ago 3 Members · 4 Replies
  • Ashish Gupta
    February 20, 2013 at 8:45 am
    Bruce,
    I think its an issue of low RAM .. your cache is very heavy and system is running out of RAM .
  • Vishesh Arora
    February 20, 2013 at 9:07 am
    Bruce
    Do you suffer from the same problem with other compositions, where there is no such PSD file? Or is it taking time only with the composition that has PSD file with it?
    From Adobe:
    With Layer Cache Indicators on, you begin to see how After Effects breaks down the RAM cache into individual layers and even effects (a). With fast attached storage, you will see those green lines turn blue as they move from RAM to the disk (b).
    Reason:
    The permanent disk cache can be a little like a huge RAM extension providing much longer memory and far greater capacity. As such, it’s in your interest to maximize its performance and, if possible, capacity. Why? Not only because faster is better; After Effects actively evaluates whether it’s in the application’s best interests to commit a given process to disk. The greater the difference between processor and cache speed, the more likely a frame gets the blue cache indicator, ready to turn green at any time (and the faster it turns green, ready for real-time).
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Bruce Gaber
    February 20, 2013 at 1:51 pm
    Thank you Ashish & Vishesh
    The problem does seem to be one of resources. When I reduced the resolution for the RAM preview AND flattened the file to reduce its size, the preview proceeded fine. The question now is which resource needs to be enhanced. I am considering adding a 4 Tb G-Raid drive exclusively for my media. If I do so, should the RAM cache be on that drive or remain on the iMac’s system drive? Comments happily received.
    Best
    Bruce
  • Vishesh Arora
    February 20, 2013 at 4:27 pm
    Bruce
    Never do that. Your disk cache should be on the fastest drive with the fastest connection. There is no problem if it will remain on the iMac’s system drive.
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
