Activity Forums Adobe After Effects Ram Preview Right, Render Queue Wrong
  • Ram Preview Right, Render Queue Wrong
    Posted by Alex Horton on December 24, 2013 at 8:00 pm
    So I’m doing an effect in AE, where im masking the top of a ramp to be replaced with a vhs effect/broll while a skater does a trick across the metal coping.
    I finished masking everything, and when i go to hit Ram Preview, it looks exactly how i want it to.
    When i actually go to add the composition to the render queue however, the vhs effect is not showing up. I made sure all the little eyes are checked, and i selected all the clips in the composition when adding to the render queue.
    Only the raw clip is showing when rendered, although i have made sure to select all layers in the composition.
    How can I make it so that all of my layers are in the final render? Because as of now, i cannot find a reason as to why all of the layers are not in.
    If it helps to know, i am using 3d as well as masking, and a null object with tracking.
    Ridley Walker replied 12 years, 8 months ago 2 Members · 1 Reply
  • Ridley Walker
    December 24, 2013 at 9:42 pm
    Is your RAM preview of the Active Camera? That’s the only one that renders.
