Activity Forums Apple Motion RAM preview out to Kona looks bad
  • RAM preview out to Kona looks bad
    Posted by Andrew Shanks on November 14, 2007 at 10:46 pm
    Hi guys,
    We have got Motion running on a MacPro Dual 3Ghz Quad – Core Intel Xeon with the AJA Kona LH card and previewing thru a new Sony Broadcast Monitor – LMD 2450. The issue we’re having is that Ram Previews on full resolution within a 16bit project (as we are working with 10 bit source material) previews text and vector graphics as if it is low resolution and aliased ….footage is fine. Same thing for RAM previews in After Effects CS3.
    If we render this out and view it in Final Cut Pro, the quality is fine and looks good. Anyone got tips for settings for optimum playback and preview as it would look once rendered ?
    In the prefs – Video Preview, Output quality is set to More Accurate. Using OpenGL. Adaptive Resolution Limit is set to 1/8
    Cheers,
    andrew
    Peter Wiggins replied 18 years, 10 months ago 2 Members · 1 Reply
  • Peter Wiggins
    November 14, 2007 at 10:57 pm
    View/RenderQuality/Best
    I bet you its set to draft
    Peter
