Activity Forums Adobe After Effects RAM Preview Memory Full
  • RAM Preview Memory Full
    Posted by Jonathan Siler on June 5, 2005 at 10:20 pm
    I have noticed a complication with AE 6.5 when using Fractal noise plugin, usually on two or more layers. When doing RAM previews, memory signifigantly diminshes each time a new preview occurs. Until eventually AE error messages that two or more frames must be viewed for a RAM Preview. Is there a workaround for this. It seems to occur on both my XP and Win2000 systems. Restarting AE works but that is awfully ineffecient. Both systems have 768 MB of RAM. Win 2000 sytem is a dual 1 GHz processor, XP is a single 2.53Ghz Pentium4. I tried all kinds of different setups in schecret menu too and nothing seems to help. Any suggestions?
    Steve Roberts replied 21 years, 3 months ago 2 Members · 3 Replies
  • Steve Roberts
    June 5, 2005 at 10:32 pm
    Are you using edit>purge>image caches between previews? You should.
    Steve
  • Jonathan Siler
    June 6, 2005 at 2:27 am
    yes. In this instance, it does not affect the memory available to the RAM Preview. In every other circumstance that option works. It is almost as if the OS or the program does not want to let go of the memory being used after the RAM Preview.
  • Steve Roberts
    June 6, 2005 at 4:09 am
    I’ve had that error every now and then, and restarting AE helps.
    Sorry I couldn’t be more helpful, as I don’t know the cause. Perhaps upgrading to 6.5.1 would help?
    Steve
