Activity › Forums › Adobe After Effects › Ram preview issues
Ram preview issues
Posted by Ruediger Chmielus on November 6, 2007 at 7:22 pmI have a problem that I cant save my ram preview anymore without AE rendering the whole sequence again…
Any clues?
AE CS3 -macpro 8GB Ram -preferences rebuilt…
Thanks,Ruediger Chmielus replied 18 years, 10 months ago 2 Members · 3 Replies -
Kevin Camp
November 6, 2007 at 8:19 pmif you are using opengl always on for previews, i believe ae will need to re-render to save.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Ruediger Chmielus
November 6, 2007 at 9:12 pmOpen GL is always off..
Ram preview will write for 5-6 seconds as normal (blazing fast out from ram)-but then will begin to render the already rendered sequence…
Ah – audio is also NOT rendered as it should be.
thanks, -
Ruediger Chmielus
November 6, 2007 at 9:30 pmThank you for your reply,
It looks almost as if there are some issues with memory -but….
I have a sequence of 40 seconds in ram-beautifully in quarter size with audio playing at 25 fps.
The full redered clip at this resolution is 160 mb.
So I have it in ram (Green Line) and save ram preview will not allow me to do this (see above)
I am very puzzeled because I never had that problem -although I trashed the prefs.
