Activity Forums Adobe After Effects Ram preview issues
  • Ram preview issues
    Posted by Peter Giffen on January 21, 2010 at 1:39 am
    Having some stuttering and issues when trying to ram preview, it only previews a few frames at a time then stops, has anyone had issues with ram preview, am i missing a setting or something. Nice new Mac Pro towers running the latest OS.
    Thanks in advance
    Dave Johnson replied 16 years, 7 months ago 2 Members · 1 Reply
  • Dave Johnson
    January 21, 2010 at 12:43 pm
    Among the first things to check are:
    • that you’re doing proper RAM previews … with the zero key or SHT+zero keys, not the spacebar … sorry, I use both platforms, but only my fingers (not my brain) recall the Mac keyboard equivalents when I’m on a Win machine as I am now
    • that you’re not using a codec that isn’t suitable for AE work … check Dave L.s “stock answer #1” for details
    • that you don’t have OpenGL turned on
    • that your machine has enough RAM, which a new Mac pro tower should
    • that you don’t have a ton of other RAM-intensive or processor-intensive programs and/or background processes running outside of AE
    • if you’re working in HD with a massive amount of layers, render-intensive effects, masks, cameras, lights, shadows, etc., etc., you may be getting the best your machine can handle in that scenario
    If you;ve confirmed that none of those things are affecting your previews, you may have some other issue going on that’ll require more info to figure out.
