Activity › Forums › Adobe After Effects › RAM Preview is deleting previously rendered frames every time I start it.
  • RAM Preview is deleting previously rendered frames every time I start it.
    Posted by Tom Small on April 3, 2014 at 8:04 pm
    I’m not sure why, but when I hit the 0 key to ram preview an area that I just ram previewed (I need to hear the audio and see the video) it seems to delete the previously cached frames that were green and start over every time. I remember older versions of AE reusing already rendered frames. I’ve looked through all my settings and searched the web… I”m on the latest version of CC with a really decked out 2010 Mac pro, and I’m using Multi-processing.
    any thoughts?
    Tom
    Tom
    Tom Small replied 12 years, 5 months ago 2 Members · 9 Replies
  • 9 Replies
  • Tom Small
    April 3, 2014 at 11:33 pm
    It does it whether I chose “from current time” or just the work area. It happens when i don’t change anything at all; I can ram preview 2x in a row and it’ll start over each time – that’s what’s baffling. All my dark and light green, previously-rendered frames in the timeline disappear the moment I hit 0, then they come back after the ram preview is done… new green frames are not added from the ram preview though. you’d think they would be stored in RAM or even on my cache disk, which is an SSD.
    Thanks for looking into this with me.
    Tom
    Tom
  • Tom Small
    April 3, 2014 at 11:51 pm
    Also, every time I hit 0, it shows “locking existing frames” and then “mixing audio for preview” – then it starts rendering at frame 1 or 2. Maybe that’ll be a clue.
    Tom
  • Tom Small
    April 4, 2014 at 2:12 am
    The audio is baked into h.264 files I received. I’m guessing this was shot on an EX-1, so not sure exactly the audio specs on that.
    When I turn of MP, ACTUALLY I just tried it again and it does keep the frames. Definitely a clue! Does MultiProcessing normally act like this?
    I have 96GB RAM, 12-core 3.46 xeon, GTX 780 3gb GPU.
    Tom
  • Tom Small
    April 4, 2014 at 6:23 pm
    Thanks for the info. That makes sense… I’m not using many effects yet until I’ve got the animation all built, just key light so far.
    Yes I’m not sure why they sent me H.264 to work with- I would never choose that codec myself for AE…
    Good to know. Thanks again!
    Tom
    Tom
  • Todd Kopriva
    April 18, 2014 at 7:43 pm
    Show a screenshot of your Memory & Multiprocessing settings.
    After Effects team blog
  • Tom Small
    April 18, 2014 at 8:43 pm
    Thanks for the response Todd. I don’t know of any other multiprocessing choices in Premiere?
    I seem to have gotten the project working by doing several things, many of which I found on this site.
    deleted all cache/preview files.
    reset Premiere preferences.
    I pulled the files I don’t need for premiere out of user/library/quicktime/
    this seemed to fix the qt32 server that I kept seeing not responding in my Activity Monitor.
    I switched premiere from cuda to openCL since one time I had an error message about cuda (out of about 50 crashes).
    I re-exported the problem last 6 minutes of the show out of FCP7 and reimported that XML into premiere.
    repaired disk permissions on Mac HD.
    restarted and booted premiere, which rebuilt all conform and pek files.
    Seems to be working ok now. sometimes it lags when i jump around in the timeline and scares me, but seems to work eventually.
    Please let me know if you have any other thoughts. I reverted back to Premiere 7.2.1 as well, and actually have the desktop creative cloud app uninstalled at the moment since I thought that might be the problem. So who knows what the problem actually was. i spent about 10 hours working on this problem trying ever configuration and step i could find/think of.
    thanks
    Tom
    Tom
  • Tom Small
    April 18, 2014 at 8:51 pm
    One other note, I have a GTX 780 video card, and I updated the nvidia driver yesterday right after I got the one cuda error message, to see if it helped. so it’s the latest cuda driver.
    Tom
  • Tom Small
    April 22, 2014 at 5:36 am
    Ok it just crashed again. i’ve worked through that area once or twice successfully, but not tonight. crashed twice. the second time I got a new error message: [/ppro721/releases/2013.10/shared/adobe/MediaCore/AudioRenderer/Make/Mac/../../Src/AudioRender/AudioRenderContextConstructor.cpp-110]
    any thoughts?
    i just uninstalled the x264pro codec trial today. I don’t know if that has had anything to do with it but it should be gone now and the problem remains…
    Tom
  • Tom Small
    April 22, 2014 at 5:41 am
    Just got another new crash message:
    [../../../ASL/Foundation/API/Inc/ASLSharedObject.h-299]
    What gives?!?
    Tom
