Activity Forums Adobe After Effects Ram Preview i n a Laptop
  • Ram Preview i n a Laptop
    Posted by Gon Perdigao on June 8, 2008 at 7:57 pm
    Hi there i know that the ram preview is shift+0, i’m working in a laptop no and i’m going crazy cause this shortcut don’t work,there is any shortcut to do a ram preview in a laptop?
    Ben Ihloff replied 10 years, 2 months ago 10 Members · 9 Replies
  • 9 Replies
  • Chris Wright
    June 8, 2008 at 10:03 pm
    since laptops don’t have extended keyboards, either use a virtual keyboard software plugin for laptops or run an autohotkey script that attaches any keypress you want to send any other key back to the keyboard buffer. One example is…
    #SingleInstance force ;only open once
    F1::Numpad0 ; Makes the ‘F1’ key send a ‘numpad 0’ key
    paste that into a text file ending with .ahk and install autohotkey
    http://www.autohotkey.com
  • Joey Foreman
    June 8, 2008 at 10:17 pm
    RAM Preview is not Shift 0, it’s just 0. Shift 0 is alternate (secondary) RAM Preview.
    I’m on a laptop as well. I just mouse over to the dang RAM Preview button in the Time Controls.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Tielman Dewaele
    June 8, 2008 at 11:57 pm
    Get the KeydUp script and arrange your shortcuts on your lap.
    https://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&extid=1242019
    T
    T.
    Quad Core Intel Mac Pro
    Duo Core Intel MacBook Pro
    Final Cut Pro 6, After Effects CS3, Cinema4D V10
    Illustrator & Photoshop CS3
    https://www.t-bloggy.blogspot.com/
  • Brett Raney
    September 24, 2010 at 3:33 pm
    fn+M on any Laptop
  • David Cabestany
    June 6, 2011 at 6:45 pm
    I tried fn-M from my macbook pro and all I’m getting is any mask available on my comps to be unfolded on the timeline, no ram preview.
  • Irene Lema
    March 12, 2012 at 9:44 pm
    Maybe a little bit late, but for those with the same problem, is ctrl+0 in a mac, as well… if it doesn’t work in composition>preview>RAM preview you can see the shortcut.
  • Samuel Ramírez
    January 7, 2016 at 6:30 am
    I know this an old post but… In any laptop the shortcut key is Fn (the blue function key) + m (or whatever key holds the cero number in the letters keyboard not the numeric strip) Remember that the numeric pad in a regular keyboard is emulated in the letters keyboard using the function key.
  • Christian Vilderman
    January 7, 2016 at 1:27 pm
    Surely you change the key commands in settings. Pretty obvious
  • Ben Ihloff
    July 10, 2016 at 4:44 pm
    Yes, ctrl-0 works for RAM Preview and ctrl-. works for audio preview on my MacBook Pro. Thanks.
