Activity › Forums › Adobe After Effects › ram preview full screen background
Posted by Donald Mitchell on March 31, 2012 at 9:11 amis there a way to set the background colour when RAM previewing full screen? It’s grey in my CS5.5, I’d like it to be black.
John Cuevas replied 14 years, 5 months ago 2 Members · 7 Replies -
Donald Mitchell
March 31, 2012 at 6:01 pmCommand Shit B?
Been to the John, it didn’t work ; )
Actually Command Shift B didn’t work either – ?
On mac, but it doesn’t seem to do anything
John Cuevas
April 1, 2012 at 3:44 amTry cntl+K and the background color option is there.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Donald Mitchell
April 1, 2012 at 4:17 pmThat’s the background colour for the comp. I need to play the ram preview full screen with a black background. Still can’t figure it out!
Donald Mitchell
April 3, 2012 at 9:50 pmNope, that don’t work either. My comp is 1920 x 1080, in composition settings the background is set to black. I have a black layer at the bottom of the comp. In the preview panel I check Full Screen, and hit the preview button. The movie plays on a grey background. By setting the appearance slider in the preferences I can get it to play on a dark grey background, but not black.
John Cuevas
April 4, 2012 at 2:13 pmAre you talking about the screen around your movie, not the background of the movie itself, but the container around it?
Donald Mitchell
April 4, 2012 at 3:23 pmYes indeed. When you play a RAM preview after ticking the full screen checkbox and the preview plays in the middle of the screen and the ae interface gets hidden, I want the surrounding grey to be black, just like when you use the present movie function in Quicktime.
John Cuevas
April 4, 2012 at 4:55 pmYou’ve discovered the controls for changing the interface color.
If necessary you could make a new compostion a little larger than your final file, create a black solid and mask out the middle. Drop your final project under the black mask and preview from there. Least then you could see what the final is supposed to look like.
