RAM Preview Fading Woes
Anytime I am RAM previewing a layer with any sort of feathered transparent edge, or an effect such as shine, the layer gets dimmer and dimmer on every pass. If I let the preview loop 10 times or more, the layer is barely visible and completely desaturated. As soon as I change anything that makes the comp update, it goes back to square one. If I actually render the file out though, everything is perfect and terrific. This occurs in both 6.0 and 6.5.
Can anyone tell me whether or not this is a simple setting that needs correction, or is it a hardware thing, or simply a standard AE problem that everybody just deals with?
