Activity › Forums › Adobe After Effects › RAM PREVIEW ERROR: need 2 or more frames to playback
Manojit Ghose replied 13 years, 6 months ago 30 Members · 37 Replies
Fandi Abu bakar
June 25, 2011 at 4:55 amThanks Denis…it solved my problem.
I’ve increase my RAM Cache Size from 10% to 50% and it worked.Thanks again…
Elvis Martins
November 7, 2011 at 2:49 amI followed the tip to use the spacebar to preview for 30 frames and the preview with the numpad 0 back to work normally…thank you mister
Guido Giardino
December 1, 2011 at 11:49 pmThis happens to me when the project file is to big. If the file size is bigger than 15mb it begins to happen. The solution is to do a “reduce project” and stay only with the comps and the files you need.
Good luck!
Elvis Martins
December 2, 2011 at 11:12 pmI discovered that sometimes I was importing files with different frame rates. My project settings to 29,97 fps when I’m importing sequences rendered from maya at 24fps. It has caused the same error. Have to check this too.
Daniel Valdez
April 15, 2012 at 7:44 amThe problem is your firewall. Disable it, and the problem will fix. I had Comodo installed. Uninstalled it and replaced with ZoneAlarm and problem has magically vanished.
Ryan Aarstad
October 6, 2012 at 10:20 pmWorking in CS6 i went to: After Effects > Preferences > Media and Disk Cache and clicked “Empty Disk Cache” Problem Solved
