Activity › Forums › Adobe After Effects › RAM PREVIEW ERROR: need 2 or more frames to playback
Manojit Ghose replied 13 years, 5 months ago 30 Members · 37 Replies
Gerardo Flores
July 25, 2010 at 7:24 pmhello Guys
Does any of you find the solution for this error?
– I dont have any footage on my comp
– I have tried changing the comp work time
– I have not done any change in the preferencesThe error is on and on comming back somethimes when I start a new comp
at the beginning it is fine and after some time (with out any of those settings changed)
the error is again thereplease some real solution 🙁
Best regards
learning after effects
Gerardo Flores
July 25, 2010 at 9:30 pmIm not using any forage in some comp and the problem is still there 🙁
Gerardo Flores
July 26, 2010 at 8:29 pmHey Guys for those like me for witch nothing of this points before was the problem:
This error is very estrange came form nothing and the solution ( at list till now )
was thisMy multiprocessing was turned off…
but as I didn’t fine any other solutions I tried this:open preferences
go to multiprocessing ( witch in my case was in off )
turn ON the multiprocessing and try to make the revisualization…
go back to the multiprocessing and turn it offAfter this non sense actions my AE start to work normally ( hope will continue like that )
Can somebody give some explanations to this estrange error and…
if was possible that with some keyboard shortcut By mistake I have changed the settings
of my revisualizations preferences ( which I will like to know )hope this will help some of you as well
Regards
G.
Nathan Burgess
October 30, 2010 at 9:02 amSo simple. Worked for me. Even before I applied the update.
system: i7 Vista64 8Gb RAM – AECS5
Muruganandam A anand
January 25, 2011 at 7:32 amHi, i too facing same kind of problem, I have just changed the preview quality quarter then it was working good instantly.
Anand21580
CG Artist -
Tommy Marxava
January 31, 2011 at 4:35 amI’m experiencing the same issue. Unfortunately, I am working from an ACER laptop, with only one processor so I cannot multi-process. However, it is rather strange because I am only using Quicktime files .MOV and .AVI which never seemed to be an issue before.
I’m just stumped.
Haluk Tarcan
March 10, 2011 at 2:09 pmnone of the above worked for me (yes, even restarting)
then I tried something and it strangely worked.
in the preview panel, near the frame rate and skip options, there is resolution. I changed it from auto to fullit worked
Aaron Nos
April 2, 2011 at 5:54 amAlright, you ready for this! This has been the fix for After Effects running out of ram while rendering the final project out and now that I ran into this 2 or more frames error I double check the settings and sure enough it was off. For some reason Adobe thought it would be funny to make a very pertinent setting hidden, so do the following and it should clear things up.
Edit – Preferences
Before clicking on an option hold the SHIFT key, while holding the SHIFT key click on any option, ie General. You must keep holding the SHIFT key till the menu opens.
At the bottom you will find the SECRET settings.
Check – Disable Layer Cache, and I put 15 in for Purge Every _ Frame
This has helped a massive amount of people I know and saved many projects from being late.
Hope it works for you.
Aaron
Ser Na
June 12, 2011 at 9:24 amFor me the solution was quite simple:
Play the composition normally for a few seconds or frames (hit the normal play button or the space bar), stop the video and then hit RAM preview. It worked for me.Cheers.
Yamir Bhatt
June 16, 2011 at 3:19 pmI had the same problem. for me a the denoiser effect was causing it. I would suggest trying to isolate the footage that might be causing it (audio, video or still) then examine the footage or effects applied to it.
