Activity Forums Adobe After Effects RAM Preview Cursor Freeze
  • RAM Preview Cursor Freeze
    Posted by Dale Paquette on February 7, 2010 at 12:32 pm
    Read some posts on freezing but not sure my problem is the same. What happens is this: I do some work in a comp and then hit the numeric 0 for a RAM preview. The rendering process proceeds as it should, one frame at a time (render multiple frames simultaneously is off, open GL is enabled) right till the end of the work area. At this point, the entire system freezes up – the cursor is non-responsive. After maybe 10 seconds, the cursor begins to jump around the screen all by itself and eventually stops. Only then does the RAM preview play out – perfectly I might add. Any ideas how to overcome this? Thanks
    BTW, I’m XP, CS3, drivers up to date, disk cache on separate internal drive (not C).
    Dale Paquette replied 16 years, 7 months ago 2 Members · 3 Replies
  • David Johnson
    February 7, 2010 at 7:04 pm
    I’ve never experienced what you described, but the first thing I’d try is turning off OpenGL. If you search the forum you’ll find lots of info about AE and OpenGL.
  • Dale Paquette
    February 7, 2010 at 7:50 pm
    Thanks, I’ll give it a try. I’ll check out Open GL in the forum as well. Dale
  • Dale Paquette
    February 9, 2010 at 1:29 pm
    Thanks all. I did end up turning off multi-processing as well as the other suggestions. Don’t know if they worked BECAUSE, in the interim I ran a defrag and a registry clean and the problem went away!! I had been suspecting a data flow bottleneck somewhere and one or more of these tips broke it. Dale
