Activity › Forums › Adobe After Effects › RAM Preview – Can someone please help me??
  • RAM Preview – Can someone please help me??
    Posted by Anonymous on July 17, 2007 at 10:17 pm
    Alright, this may seem trivial to most of you, however I’ve been doing this for 3 months so please bear with me. For some reason when I try to do a RAM Preview, it doesn’t preview the full composition. Say my composition is 20 seconds…..It will only render out 11 and a half!!!! Can someone please help me???
    Jeff Mcbride replied 19 years, 2 months ago 3 Members · 2 Replies
  • David Bogie
    July 17, 2007 at 10:47 pm
    the usual issues:
    you don’t actually have enough RAM
    you are using it too fast because the comp settings are too high
    you’re on a newer Mac and AE tends to use RAM really weirdly on the Intels.
    you have set beginning and ending markers
    bogiesan
  • Jeff Mcbride
    July 18, 2007 at 2:17 pm
    You could also try purging- go to Edit–> Purge All and then try RAM previews. Sometimes it just gets stuck and you have to purge before it can render on.
    Another tactic I employ all the time is instead of typing Numpad 0 to RAM Preview, type Shift-Numpad 0. This will render every other frame so you can preview longer (and quicker.)
