Activity Forums Adobe After Effects ram preview automatically purged
  • ram preview automatically purged
    Posted by Efi Or on May 29, 2010 at 5:52 pm
    sup everybody.
    got here a little issue.
    ram preview automatically purged, and I have NO IDEA why. everything was ok with the ram preview since ever and suddenly this issue came around.
    and yes, pressed ALT CTRL SHIFT while booting ae and reset all pref.
    also, enabled disk cache, and restarted the windows.
    after ram preview is done, the green line disappeared and I cant move the the indicator timeline without get the low fps/low resolution.
    so whats up with it guys?
    Efi Or replied 16 years, 3 months ago 2 Members · 3 Replies
  • Walter Soyka
    May 29, 2010 at 6:16 pm
    This happens if your viewer settings don’t match your RAM preview settings. In other words, if you are viewing at 100% / Full, but RAM previewing at 100% / Half, the green line will disappear after RAM preview because it doesn’t have any full-res frames cached. If you initiate another RAM preview, the cached half-res frames should re-appear.
    If you change your settings to match, the green line shouldn’t disappear.
    Walter Soyka
  • Efi Or
    May 30, 2010 at 5:02 am
    Hi Walter, thanks for trying, for no, both on FULL, tried to work with half res as well, nothing.
    maybe something else?
  • Efi Or
    May 30, 2010 at 5:28 am
    ok, re-checked this issue here, and seems this problem appear only in one project.
    maybe I pressed here sometime mistakenly? comp settings?
    thanks.
