Activity Forums Adobe After Effects Ram Preview a section only
  • Ram Preview a section only
    Posted by Nic Beery on October 9, 2010 at 2:38 pm
    I’m on a mac pro 8 core, just updated to AE 10.0.1. When I used to select a section to ram preview using the B and N keys to select a section, and then hitting the 0 on the number pad, it would play only the selected area. Now it starts from where the play head bar happens to be and plays the whole sequence. I would like it to do what it used to in previous versions, play just the selected area.
    Is there a pref that I have not selected?
    Nic
    Nic Beery replied 15 years, 10 months ago 3 Members · 6 Replies
  • Andrew Devis
    October 9, 2010 at 5:54 pm
    If you expand the preview panel down you may find you have the ‘from current time’ check box checked. If this box is un-checked then the ram preview will be from the start to the end of the work area.
  • Nic Beery
    October 10, 2010 at 1:40 am
    I am sorry to sound so ignorant, but what is the “preview panel”? do you mean the timeline? I looked at all the buttons and switches on it and none of them said anything about playing selected work area.
    Or do you mean preview pane in preferences that talks about open GL?
  • Andrew Devis
    October 10, 2010 at 3:01 pm
    The preview panel is usually on the right hand side towards the top and has some play buttons on it for RAM preview. If you can’t see it go to the windows menu at the top and look for ‘preview’ and click on that to show it. Then, you can pull the bottom of the panel down by putting your cursor over the line between the two, clicking and draggin it down. Then you will see the check box I mentioned. Hope this helps.
  • Nic Beery
    October 11, 2010 at 2:01 pm
    Andrew, That did it! Thanks so much.
    -Nic
    https://www.BeeryMedia.com
  • Michael Szalapski
    October 12, 2010 at 2:25 pm
    As someone just starting out in AE, this set of resources was built especially for you. Go through these now and save yourself a ton of headaches later.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Nic Beery
    October 12, 2010 at 2:35 pm
    Thanks for the resources, I’ll check it out. I’ve actually been on AE since 1998, just needed to find a few things on AE 10.0.1.
