Activity Forums Adobe After Effects Ram Preview
  • Ram Preview
    Posted by Matt Rinaldo on July 18, 2008 at 2:36 am
    I has working on a 12 sec project today. It was in 1080i 30p but there was no video in the comp I just needed the comp dimensions to match my fcp project. When I was almost finished with the project I did a ram preview and the green render bar would only go to about 7 sec or so and the stop? then it would play back the 7 sec or so (what was ram previewed)
    I had the work bar just above the timeline extended the entire length of the comp. and when I was finished I rendered the project into a quicktime and it was all there all 12 seconds. So why was the ram preview only ram previewing the first 7 sec? could this have anything to do with the comp being in 1080i ?
    also should you interpret a still picture?
    do u get better results if you render q a nest comp or does it not make any difference?
    can anyone suggest things that I could do to my mac (g ) at work to keep it running better.
    thanks
    matt
    Matt Rinaldo replied 18 years, 2 months ago 2 Members · 2 Replies
  • Michael Duff
    July 18, 2008 at 3:35 am
    RAM preview will only preview as much as it can store in the RAM … get more RAM, or preview at half quality … or just preview in short bits …
    Pictures, photos, graphics etc should be interpreted as Fields OFF … unless for some reason the still image has come from interlaced video.
    Shouldn’t make a difference if you render the nest or if you render the comp.
    Michael Duff –
    Bearcage Productions, Australia
    http://www.bearcage.com.au
  • Matt Rinaldo
    July 18, 2008 at 4:52 pm
    thanks
