Activity Forums Adobe After Effects Expressions RAM preview “2 or more frames” question
  • RAM preview “2 or more frames” question
    Posted by Justin Hawley on May 16, 2005 at 5:52 pm
    Hello!
    I recently got After Effects 6.5 (after working on 5.0) and the RAM preview was working GREAT! Now, I get an error stating “RAM Preview needs 2 or more frames to playback.”
    Please advise,
    Justin.
    Mylenium replied 21 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Steve Roberts
    May 16, 2005 at 5:56 pm
    I get that every now and then — not sure why, but quitting and relaunching AE fixes it.
    Don’t forget to save incrementally. (file01.aep, file02.aep, etc.)
    Steve
  • Aroonzfx
    May 16, 2005 at 6:13 pm
    hi all
    i also get the same error frequently..
    no way to handle such error,,
    i think adobe should provide some upgrade patch to fix this
    as steve said.. quitting and relaunching AE fixes it…
    unfortunately the only way right now………
    aroonz
  • Justin Hawley
    May 16, 2005 at 6:14 pm
    Thanks for the replies, guys. Are your motherboards and all hardware compatible? I know ours is not completely, and am just curious if that is or is not definitely the problem.
    Thanks again!
    Justin.
  • Mylenium
    May 16, 2005 at 7:03 pm
    Nope, that’s not hardware related. It’s a memory leak/ bug in the way how AE treats the composition pixel buffer. Certain plugins or expressions will cause this ‘cos AE won’t allow that buffer to be refreshed properly.
    Mylenium
    [Pour Myl
  • Patrick Pathmanathan
    May 16, 2005 at 7:48 pm
    have you upgrade your AE6.5 to AE6.5.1 from adobe website. Try after upgrading it.
    -Patrick.P
  • Visual_guy
    May 16, 2005 at 8:50 pm
    I’ve had this happen on the PC, and I’m pretty sure it’s a memory leak also.
    Try the “purge all” in the edit menu. That should clear out the cache without rebooting.
    Brett
  • Justin Hawley
    May 16, 2005 at 9:16 pm
    Thanks for so many wonderful posts! It seems to be working again, after rebooting it always works, only now it seems to be temporarily “fixed”. I’ll take all your thoughts into consideration. Thank you!
    Justin.
  • Mylenium
    May 17, 2005 at 9:39 am
    [Patrick] “have you upgrade your AE6.5 to AE6.5.1 from adobe website. Try after upgrading it. “
    Nope, the update won’t fix this, the problem is still there.
    Mylenium
    [Pour Myl
