Activity › Forums › VEGAS Pro › RAM / Memory for Vegas Pro?
  • RAM / Memory for Vegas Pro?
    Posted by Matthew Jeschke on February 15, 2012 at 2:25 am
    I’m assuming my issue is I don’t have enough memory / ram for vegas to run well.
    I typically edit small veggies, around 5-10 minutes in length. These are my scenes. Then I put these into a master veggie for the whole project.
    My master veggies are typically around an hour long. All standard def stuff (I don’t do HD yet).
    If I switch windows say to edit a child veggie the whole works typically crashes so I avoid this as much as possible. However, sometimes it’s almost necessary to open a nested veggie.
    So I’m curious, how much memory is enough. I have 4 gigs of system RAM. How much do you typically have when your system can handle multitasking with vegas.
    And or, are there some virtual memory settings, or any settings for that matter, I can change so it doesn’t crash as much?
    I’m learning the ropes of online publishing. Mostly as an excuse to play with more cameras.
    Here’s several of my latest ventures,
    https://www.keystoaz.com
    https://www.fitlish.com
    https://www.corvettemedic.com
    Mike Thomas replied 14 years, 7 months ago 3 Members · 3 Replies
  • Jeff Schroeder
    February 15, 2012 at 1:39 pm
    We need more specs on your computer. Try Speccy from https://www.piriform.com.
    Jeff
    Windows 7 64-bit, ASUS P6X58D, i7 960 3.20GHz, 24.0GB DDR3, 12TB connected storage
    http://www.narrowroadmedia.com
  • Mike Thomas
    February 15, 2012 at 10:10 pm
    Greetings Matthew. My workflow is similiar to yours in that I work on 3-5 minute “scenes” with my master project usually 1-2 hrs long. I had a dual core, 2.55ghz, with 4gb of RAM and had all sorts of trouble rendering out my master projects. I added 4 more gb of RAM and no more trouble. So I suggest adding more RAM for starters.
    Just this week though I’ve been trying to render out a 2 hr. HD project as an uncompressed Quicktime and I’ve had lots of “errors” and very long render times. Never did get it so I settled for an uncompressed AVI which rendered out fairly fast.
  • Mike Thomas
    February 16, 2012 at 10:18 pm
    I meant I have a quad core.
