Activity › Forums › Maxon Cinema 4D › RAM ISSUES INTEL-MAC
  • RAM ISSUES INTEL-MAC
    Posted by Jonas Espinoza on October 9, 2007 at 5:12 pm
    I am running AE CS3 and C4D 10.111 on an 8-core macpro with 4gb RAM, soon to be upgraded to 8.
    I am having bad interface response with c4d and AE. Not sure if its the graphics card radeon 1900, or RAM.
    in c4d after i render a viewport, when i click off of it to say the object manager, it takes like 10 seconds for it to go back to an editor view.
    also, i get garbled blocks of interface chunks when scrubbing values with a light.
    in AE, my ram previews often dont work. i have to set it back to adaptive. IS OPEN GL a joke? or is this graphics card not really so hot? it did come in the top flight macpro…
    I was excited by the speed of this machine, but right now it is not acting optimally. is there anything outside of more ram to optimize this thing. I am running cocktail. I see in my activity monitor that only like a gig is being used. could i have bad ram? has anyone had an experience like this???
    Kelly Johnson replied 18 years, 12 months ago 2 Members · 1 Reply
  • Kelly Johnson
    October 10, 2007 at 3:01 am
    Make sure you’re RAM is sitting clean.. meaning installed correctly. Depending on your configuration, RAM still needs to be installed in pairs; even on the quad/Xeon machines.
    Check that first. Maybe it’s not fully in or mixed out-of-pairs.
    Change your resolution to the next lower setting and see if that does anything. That would be a test for the vid card. Better yet, crank it down to 800 x 600 and take it for a spin.
    I’m only on C4d 8.5 but I also run CS3 apps, including After Effects and I don’t have an issue and this is on a G5 iMac (non-Intel)
